Flite - recovering one in white/ cream or red leather
d8mok
GT Fan
I’ve a very tatty Flite saddle which I’m considering recovering
To fit with a project it could go either white/cream or red.
Does anyone have a source or link to appropriate leather to use ? I assume it needs a bit of padding and to be stretchy.
I did 2 fights in Alcantara as an experiment....along with a rolls and a turbo. However, it made it quite a hard job as there is very little if any stretch.
You deffo want something with a small amount of stretch, which leather naturally has, especially with the aid of a little moisture.
I’ve found a mint condition WTB SST-K in a drawer.
Would it be crazy to try to use that to recover a Flite. 🤔
if you are going with real leather then soak it for 24 hours before hand, you want 0.9 to 1.2mm thickness. if you go with something fake (preferable to be honest) then look for something with 4 way stretch like upholstery leatherette
the padding comes from the foam, don't get anything with padding stuck to it.
you can get upholstery leatherette on ebay for cheap, buy about twice what you think you'll need, although most places only sell by the metre anyway, this will give you enough to pull it about and stretch it. be aware that it will have a bias i.e. it will be stretchier in one direction than the other, from memory you want it to be stretchy across the saddle not along it.
you'll also want a bloody good stapler. :)
This what you need, https://www.ebay.co.uk/itm/225597193262
No need to pre treat as it already has enough stretch, use a contact adhesive such as evo-stik or Bostik. When removing the old cover peal it slowly as the adhesive can pull pieces of foam with it, I use a small hand held steamer when doing this to soften the adhesive & they can used to reshape compressed foam.
I've a very tired flite I may have a play with like this. I'm sure Mike muz did a zebra one a few years ago?
IMG_7739.webp IMG_7740.webp Bumping this back up as I’ve ended up with a sorry looking 1992 Flite.
Under lots of gaffa tape is this
The foam is ripped and partially stuck to the tape.
I feel it needs recycling into a nice saddle.
Yes I did a zebra one and a perforated red one. The former was fabric, short term it was good but hard to clean. It was only done for one or two events.
The red perforated one was leather and sits proudly on my Gary Fisher Supercaliber to this day, I just used contact adhesive and pegs to hold it in place for a while.
