What do you think of Shimano ditching rim brakes in 105 and higher?
Really? Which mechanic takes that long?
Bearing changes with aheadsets are so simple. Release the stem, drop the forks, knock the bearing out (you usually only replace the lower one), slip in new bearing, replace forks and stem. Job done. 30 mins.
Did one yesterday so I'm now an expert.
Internal routing for the hydraulic brake lines
Aheadsets, that's soooooo yesterday
