I may have made a mistake! 1999 GT XCR 3000 i drive.
Turbo12
Just bought this bike, intending it to be my daughter's first adult sized bike. However I failed to take into account the ground clearance! The frame is fine once she's on it, but getting on it is quite a struggle!
However, the bike is much better condition than I expected, 1 owner from new! But it's a small size frame, and I'm 5'11", so I guess it's too small for me? Trying to find some justification to keep it, help me out!
To be expected. I noticed that on my hardtail vs FS the distance from saddle to pedal is identical, but everything on the FS is about 2 inches further from the ground. I have to dismount the saddle and straddle the top tube to get both feet on the ground. One of 3 things will happen; it’ll require some adaptation to ride, she really will grow into it, or ol’ dad has a sweet GT.
I've only had hardtails before, so just hadn't thought about it. She will grow into it eventually, but there is a danger I might nick it before that! Just not sure if it's a big enough frame for me. Suppose I better sneak in a ride when she's not looking!
find a hardtail frame cheap. (something like a Carrera or similar, just about good enough quality but dirt cheap on the evilbay)
swap the parts till she's grown enough.
swap back.
It’s not. At 5’11 you should be on a large. I’m sure you could make it so you physically fit on it, but it would never ride remotely well.
That generation of GT were never amazing. Suspension pivots needed a lot of maintenance and the dog bones and bolts broke often enough to be considered consumables, but to be fair, that looks like a pretty good example.
Frames swap could work, but personally I’d keep as is and find a short term bike until she grows a bit, if you have the money. The way prices are, I doubt you’d lose money on a short term flip.
