Sugino mighty 900 Q factor ? Similar to Ritchey logic ? Other ST cranks with low stance width for 1X set up ( will use between 34 and 28 T )
willywombat64
Still trying to reduce the Q factor on my Pugsley build as with standard external cups and cranksets it's around 210 mm which irritates my arthritic knees a lot !
I have just tried a stronglight chainset (80 ? ) model I believe which works well on the drive side regarding reducing the chainstay gap and keeping the correct chainline it would seem , but the left hand crank on the 147 spindle touches the chainstay
I have since gone through numerous lh arms and found a cheapie that seems reasonable clearance wise .
I would like to find an inexpensive half decent solution and it seems ST is the only way so came across the sugino mighty 900 and Ritchey logic .
I know they come in different versions ( compact and sub? compact) .
I guess the compact is better for me as they allow smaller rings ?
Can anyone in the know advise re the difference between the sugino m900 and the Ritchey cranksets?
Is the mighty 900 similar quality ?
Would the Q factor be similar do you think ,..I cannot find info anywhere . Sheldon has figures for the Ritchey models .
If you do know the approx Q factor and BB length ( producing that for the mighty 900) it would be very much appreciated.
Also ..any suggestion for other ST chainsets that might do the job and not cost the earth .
Spa cycles have a TD 2 with a low Q factor 153 on the double ( 110mm BB) but 34 T is lowest I could go because of the bcd .
Thanks in advance
Bill
Good to see someone caring about q/tread factor👍
Rarely talked about but really important ! Changes a bike hugely ....
Don't know a pugsley....what size BB shell is it?
I'm surrounded by random frames cranks and BB sizes in my workshop right now...
it's a 100mm bottom bracket ..the smallest width available on most fatbikes unless you go custom / mod your frame by shaving the shell to take an 83mm bb or buy from someone like waltworks iirc . Those frames are far from cheap... even more so importing from the states.
I couldn't believe how the increased q factor messed with my knees . One 30 mile ride and I was in pain for 10 days . I normally ride flats but with pins they can be worse than clipless re not allowing float or the knee/leg some rotational leeway. Others have some success with orthotic wedges and massaging /lengthening tight adductors . Anecdotally there are many riders who cannot ride any fatbike because of the knee/ q factor issue. I'm no small guy either and have long legs but deal with medial knee wear which gets irritated easily .
I couldn't do a tread with much over 150...210 is like putting peddles on a cow!
Tyre size and how they effect chainstay will always dictate q factor...and then chainring tooth count has to fit in between them!
I have zero frames with a shell like that...68 or 73 keeps it all sensible......I've just managed a build with a 73mm shell, 45 tooth single 1/8 chainring and a q of 150.5.....tyre clearance for 2.35..you won't really squeeze much more than that!
A fat bike will always be that....fat. 😐
I've got some Sugino Mighty 900 cranks and I'm using a 107mm bottom bracket(68mm shell). The q factor appears to be approximately 160mm.
The LX m563 is slightly wider using the same 107mm bottom bracket (around 165 mm) and cheaper and easier to get hold of.
