Wanted 4 Bolt disc brake rotor for Coda hub - 160mm or 140mm
jimbog
Hi gang, sorry probably the wrong section age wise but I need a 160mm or 140mm disc brake rotor with 4 bolt fitment a la Cannondale coda hubs circa 1998 - 2000. Does anybody have anything please?
Possibly - I’ve got some 4 bolt rotors that fit Hadley and I think Formula somewhere out there. Any idea what the centre bore and the distance between the bolt holes is on the ones you need?
I’m actually looking for more 140mm as the front rotor is more that size. 160mm seems too large.
I’ve had a look and I do have some as below.
The one piece ones are the same bore and bolt pattern as yours, I think they were either Coda or Rohloff pattern when I bought them. Both are 165mm though - can you get an adaptor to make that fit? Think that’s what I was running albeit the front was a 185mm as the two piece ones below that had a much larger centre bore and bolt pattern.
The two piece ones with alloy centres are Formula, the front is 185mm and don’t think will fit your hubs. The rear is 140mm and would fit. I’d want to sell these with my GT Hadley hubs as they are pretty much useless without these obsolete discs. Just included so you could see it’s worth including Formula in your searches.
