ishaw":1u0q6rzb said:You can swap the freehub over and then use a 7sp cassette with your shifters. Later shifters could be adjusted between 7 and 8 via a twisting the top cover, they would usually have markings to show this if not worn away.
I have a new xc pro hub body and freehub, if your hub is xc pro, you could swap over the freehub.
