Sold MovedReduced: Mavic All-Road Disc (CL) 700c wheelset (low use and tubeless tape installed) Shimano 11sp freehub
BLACKTWANG13
Old School Hero
Less than 700 miles use so perfectly functional with only a few light scratches and a cpl small nicks on the decals as pictured which don't affect use. Super smooth and true. With DT Swiss center lock lockrings as pictured.
100/142 thru axle compatible (QR and 135 end caps available separately)
MAVIC ALLROAD DISC WHEELSET 2021
The Mavic Allroad is a reliable and versatile disc wheelset that performs admirably over rough roads, gravel and dirt when on bike packing adventures, long weekend rides or the daily commute.
Strong and laterally stiff aluminium rims provide all of the speed and resilience needed for tacking rough terrain at pace. These rims possess 22mm internal width measurements that support the sidewalls of broader tubeless-ready or standard clincher tyres, helping them perform with lower rolling resistance, increased traction and heightened comfort.
A resilient aluminium hub shell encases smooth spinning bearings and combines with the strong steel spokes to grant more even build tensions. This heightened build accuracy naturally improves power transmission and braking precision markedly.
INCLUDES
Pre-installed tubeless rim tape
HIGHLIGHTS
A dependable wheelset that performs over rough roads, gravel and dirt
Aluminium rims are light, strong and laterally stiff
22mm internal rim width mates perfectly with very wide tyres to lower rolling resistance and permit lower tyre inflation pressures
Alloy hub shells are light but stiff to provide a solid base for disc brake rotors
Hub automatic bearing preload adjustment gives added bearing durability
Instant Drive 360 freehub provide fast engagement under acceleration
24 strong spokes, front and rear are laced in two-cross patterns to provide positive disc brake modulation and heightened durability
FEATURES
Tyre compatibility: UST tubeless-ready clincher
Wheel size: 700c
Rim: S6000 aluminium
Rim profile: Symmetrical
Rim finish: All black, satin surface
Rim depth: 22mm
Internal rim width: 22mm
Rim internal format: Hooked
Spokes: Mavic steel straight pull, round
Spoke count: Front - 24 / Rear - 24
Spoke lacing pattern: Front - two-cross / Rear - two-cross
Hubs: Front - Mavic aluminium disc brake / Rear - Mavic aluminium disc brake with Instant Drive 360 freehub
Freehub compatibility: Shimano HG/SRAM Road 11-speed
Brake compatibility: Disc Center Lock
Front axle: 12mm x 100mm thru-axle compatible (Convertible to Quick Release with optional adapters (available separately))
Rear axle: 12mm x 142mm thru-axle compatible (Convertible to Quick Release and 12x135 thru-axle with optional adapters (available separately))
Recommended tyre size: 28mm to 64mm (1.1” - 2.5”)
Maximum tyre pressure: See indication on wheel and tyre. If they differ, use the lowest of the two
Maximum recommended rider weight: 120kg/265lbs (including rider, bike and any other luggage)
Manufacturer claimed weight: Front: 870 grams / Rear: 1020 grams / Wheelset: 1,890 grams
£160 posted to your door NI and UK mainland only
